For Ipod Users: How To Watch Videos On Ipod Touch, Ipod Nano, Ipod Classic, Ipod Shuffle
The world’s smallest music player iPod shuffle is coming to our daily life.
It is small---1.8" tall by 0.3" thin
It is huge---VoiceOver tells the names of your playlists when you click the button
We all know that ipod has many generations. Every generation has its particular functions. Some specialize in music, some pay more attention to video function, others emphasize convenience. Different patterns provide different functions. In the following text, I will share a nice guide to tell you how to enjoy dvd/video on iPod Touch, iPod Nano, iPod Classic, iPod Shuffle
Preparation:
OS: Windows NT4/2000/2003/XP and Windows Vista
Software: 4Videosoft DVD to iPod Suite
Hardware: 800MHz Intel or AMD CPU, or above; 512MB RAM or more
This guide has two parts:
1.How to put dvd on iPod Touch, iPod Nano, iPod Classic, iPod Shuffle
2.How to put video on iPod Touch, iPod Nano, iPod Classic, iPod Shuffle
Part 1: How to put dvd on iPod Touch, iPod Nano, iPod Classic, iPod Shuffle using 4Videosoft DVD to iPod Converter
Step 0. Free download and Run 4Videosoft DVD to iPod Converter .
Step 1. Load your DVD
Put your DVD in your DVD drive and click "Load DVD", you can load your DVD, DVD folder, and also IFO file.
Step 2. Choose your output profile and settings
At the lower part of the interface you can find a "Profile" drop-down list, you can find one for yourself.
Click "settings" on the right side of "Profile" you can adjust your output's settings, such as "Resolution", "Frame Rate", "Bitrate" and so on.
Step 3. Start Conversion
If you don't want any more editing just Click "START" button to start your conversion.
Part 2: How to put video on iPod Touch, iPod Nano, iPod Classic, iPod Shuffle with 4Videosoft iPod Video Converter
Step 0. Free download and Run 4Videosoft iPod Video Converter .
Step 1. Click the "Add Video" button to import the video files you are going to convert. Alternatively, you can click "File -> Add Files..." to load the video files.
Step 2. Extend the "Profile" category to select an output format.
Step 3: Start conversion
Click the “Start” button to start your conversion and in a short while it will be finished.
Tips:
1.Trim
If you want to cut your DVD movie into many different parts, or you just want to convert one part of the movie, just use “Trim” function.
3 methods for you to complete this:
a. Drag the slider
b. Click “Start Time” and “End Time” button
c. Set the value
2.Crop
"Crop" function allows you to remove the black edges and customize the aspect ratio
3 ways for your to do this.
a. Selecting the crop mode
b. adjusting the crop frame
c. setting the crop value
You can customize the your own aspect ratio using "Zoom Mode". It provides you "Keep Original", "Full Screen", "16:9" and "4:3".
3.Effect
Click "Effect" button you can adjust brightness, contrast, saturation and volume easily.
4.Merge and Snapshot
"Merge" function enables you to put many chapters into one output video file
"Snapshot" allows you to capture the picture of the movie you like
5.Audio Track and Subtitles
You can choose the audio track and subtitles before conversion (If your DVD has different audio track and subtitles).
At the end of this article, I will share you two useful tools.
iPod Manager
iPod Manager for Mac
Video Converter
With it, you can share your videos and songs to your friends. Because it can help you to manage videos, audios from one iPod to another iPod.
Hope this guide can offer you a chance to much more enjoy your ipod.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
