ey fellas
got a bit of an issue here i had an RB25DET in my r32 gtst-4 and now im putting the RB into a 180sx i took the 4wd sump off and bought a standard RB25 sump from jap parts plus.. When i wen to put it on this arvo nothing lined up the sump seemed to short which leads me to believe they have given me the wrong one
just wondering if anyone has any other possible ideas to why the so called standard sump doesnt line up with motor??
cheers
https://www.sau.com.au/forums/topic/300559-sump-issues/
what would be the best suggestion im going on atm buying a rwd 25 bottom end and smashing the head off mine on it... or just buying a cheap 25 unless thesre is someone or some shop that possibly sells custom sumps...
https://www.sau.com.au/forums/topic/300559-sump-issues/#findComment-4992774
You can always remove the front diff and mod your awd sump @ embleton or some other ally welder
if you want to go as far as swapping blocks then RB30 would be cheaper, more torque and theres a few rb30 modded sumps on the market
https://www.sau.com.au/forums/topic/300559-sump-issues/#findComment-4993574
If you're going that far might aswell get a 30 bottom end and smash your 25 head onto that..
Pretty sure that's your answer to everything....
Lyell can you replace that light globe in the lounge room? "Yeah, I'll smash an RB30 up there" :D
https://www.sau.com.au/forums/topic/300559-sump-issues/#findComment-4994089
Lyell can you replace that light globe in the lounge room? "Yeah, I'll smash an RB30 up there" :)
LOL Nathan.. at least in this instance it's actually cheaper and better if he's considering swapping to a rwd block!
P.S. I was waiting for this :(
https://www.sau.com.au/forums/topic/300559-sump-issues/#findComment-4994691
problem solved guys, was thinking of the 25/30 conversion but in the process of a hopeful/ succesful 26/30 build for my 32..
as i was removing the silicon from the bottom of the block i started digging up little 10mm thread holes in the block, once i cleaned the bottom of the block and changed the pick-up ad dropped the 25 sump on it all lined up, the guys who did the conversion on the car before i bought it muct of tapped out new holes for the 4wd sump and diff... all the stressing and all i had to do was clean it abit
thanks for the advice fellas have a good chrissy!
https://www.sau.com.au/forums/topic/300559-sump-issues/#findComment-4995144
Second set holes are on all 4wd blocks . If your using tin sump how did you modify mount brackets for bottom row of bolts to hold box against block ??
https://www.sau.com.au/forums/topic/300559-sump-issues/#findComment-4995511
Are you talking about the wings that bolt to the bottom of the bellhousing?
https://www.sau.com.au/forums/topic/300559-sump-issues/#findComment-4995761
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
