item- z32 amfs witht tomei plugs to fit a skyline gtr
reason for sale- reason for sale is tuners of my car think that these afms are too big for my application so thinking of going back to standad or get a pair of nismos, these will suit a application if you are aiming for some big power in the future but for me im nonkig of getting oer 300kw so these have to go to try cover the cost of the new afms,
will seperate only if i have a buyer for each one of them
located in melbourne northern suburbs,
price-$270 firm each or both for $520 firm
contact steve 0412862091
  • 3 weeks later...
