Hey Everyone
I been thinking for while of getting a FMIC, but now that ive starting looking into it theres alot of different sizes and core dimensions etc...
I have a series 1 GTS-T M-SPEC will the FMIC fit without much mods to the front bar?
Just wanted to know what other people have put on and dimensions please.. my Budget is about $2000 installed i dont want to blow my budget.
Im also getting the exhaust done dump pipe and high flow cat any recomendations on that would be great also!
Thanks!
https://www.sau.com.au/forums/topic/30089-fmic/
You have to cut the bar for any decent sized fmic. I haven't done it myself but the workshop that installed the fmic did so without too many dramas. I don't think it's that hard.
Dump pipe and cat - get one of each from BATMBL! See the car parts trading forum.
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-611765
I'm thinking of putting a GTR cooler on mine... I figure i only wanna run around 12-14PSI (GTR runs that) and it should virtually bolt straight on no worries...
Plus I only wanna take the car to a max of around 200RWKW (for the time being) so the GTR cooler should do the trick...
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-612668
Dimensions i think are around 600x300x70 (but don't quote me on that. Piping work is easy, just take it an exhaust place and they'll get it done for you for around $300-$400.
Sounds like a GTR intercooler will do the trick!!! Thanks alot Guys now have to start find one for a good price.
What u reckon is a reasonable price? $500-700??????
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-613350
If you don't want to cut the front bar yet still get good performance out of the IC use a Bar and plate.
Mine fits perfectly behind the front bar.
Its rated at its optimum of 580hp with a 1.5psi pressure drop.
From memory its got 60-63mm inlet/outlet 2.5", 600 x 300 x 90. I think.. :D
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-613384
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
