If you've been playing around with double-clutching, along with all the before-mentioned symptoms I'd say your clutch is on the way out. You may have been burning it quite well while you were learning to double.
@David
Car revs as normal, I was very sure whe boost was taking longer to spool, but that may have been my imagination. When the car was running, it took ages to build speed. But as I said in my last post, car is no longer working. Just sits there in first revving its heart out.
@Mosquito
Given the fact I've never had any issues with the clutch before now. I'd say I probably did stuff it while learning to double.
If the clutch is gone, should I go ahead and get my syncros replaced while the box is out?
Can anyone give me a ball park figure on getting my syncros replaced?
Cheers
Edited by Aidan
Id also say forget about the synchros, just get a new clutch. Exedy OEM replacement + labour goes aroun 600-800 total, roughly...
Or go for an Exedy Heavy Duty + labour maybe around 800-1000?
If the turbo suddenly takes longer to spool up the issue could be a blocked/collapsed catalytic converter.
I had a hi flow metal cat that I bought through an SAU group buy a few years ago, that the insides collapsed and blocked up a few months ago.
The only symptoms were a slower spool up of the turbo, and my peak boost decreasing below what the EBC is supposed to maintain.
I thought the Boost controller was the issue, so I swapped that out, with the same results. So next I thought the wastegate could be the issue, and swapped that also. After this didn't fix the problem, I took off the cat and had a look. It was almost completely blocked due to the breakup of the stainless mesh inside.
It was a frustrating learning experience, as the cat would have been a pretty simple thing to initially check. I guess I figured when you spend good money on a stainless "Magic Cat" it should last more than 18 months.
Sorry to hear about your gearbox breakage, but while your fixing that issue, I'd also take the cat off and have a look inside.
Ahh double clutching should be more beneficial for your synchros but only if you do it right! If you rev too high and engage the clutch it will jump forward and put more strain on the drivetrain and too low will make pull it back similar to normal downshifting. The whole idea is to keep it smooth and get the revs matching right before engaging the gear. It should be seamless between downshifts.
Edited by Ruff Ryda
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
