i have for 96 r33 gtst, s2
Bonnet $150
Right Guard $70
Right Headlight $60
Rigt Door with trim $70
Boot with Spoliler $80
Rear Bar $70
Rear Lights $60 pair
Front Winshield $100
Rear Winshield $100
Rear Left Quarter window $60
Rear Right Quarter Window $60
S2 Steering Wheel, (airbag) $150
Climate Control unit $100
Front Seats, No tears. $150
Rear Seats, No tears $70
Dash Board, (airbags) good condition $200
Centre Consol $50
Roof Lining $70
Rear Right Top Quarter Trim $40
Rear Right Bottom Quarter Trim $35
Rear Left Top Quarter Trim $40
Rear Left Bottom Quarter Trim $35
Floor Carpet, good condition $80
5 Stud Conversion
Front'' right and left
Brake Calipers (sprayed red)
Brake Pads (good condition)
Rotors
Subframe
Suspension Components/no coilovers
Brake Line
5 Stud Hubs
Everything Exept coilovers
All in one piece
All bolts Included
''REAR'' right and left
Rotors
Brake Line
Handbrake Cable
5 Stud Hubs
Diff Shafts
Suspension Components/ no coilovers
Everything Exept Coilovers
All in one piece
All bolts included
$1200ono
any other parts you need, ask i will have
If you need pics, ask i will post
Western Suburbs, Melbourne
Edited by boz_soljah
https://www.sau.com.au/forums/topic/301476-wrecking-r33-gtst-s2/
  • Replies 102
UPDATE !!!!
Wiper Washer Bottle $20
Radiator Overflow Bottle $20
Radiator, Fan cover, Support $100
Ac fan $20
Ac Radiator $50
Bonnet Release Cable Setup $30
Centre Dash Piece $50
Cluster Surrounding $50
Centre Console $50
Bottom Dash Steering Cover $20
Right Console Cover $10
Steering wheel cover $10
Side computer cover $10
Glove box with pins $20
Glove box, Behind part $20
hey mate, can you please PM me a close up shot of the right side tail light assembly?
if it's in good nick i'll certainly take it off your hands :)
cheers
pm sent
Hi there I'm after a aircon condenser... Do u have one for sale??? Think it's the ac radiator u have fir sale but not sure??? Can u please let me know what condition it's in and where ur located please??? Thanks heaps!!!!
If anyone has an a/c condensor for sale please let me know thanks heaps!!!
yes i do have it, pm sent
Hey mate, have you got the large heat insulated line that goes from the aircon into the firewall and normally silver in good condition?
pm sent
Do you have the plastic inner guard for the right hand pasenger side?
Also the right hand mirror assembly? My retractible mirror motor is broken.
pm sent
gday, how much for the front calipers and where are you located?
cheers
hay, im selling the complete 5stud conversion for $1000, front and rear with all parts, all suspension components, the whole lot, if you want just the front i can give it for $500, complete with all bolts, hubs, calipers, brake line, suspension components, look in pics, let me no
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
