hey,
We are selling our spare RB26DETT engine, removed from a mechanically perfect 1994 r32 gtr with 70,000k's, engine has been very well looked after by the previous owner, who went to great lengths to keep it in imaculate condition, and he also reconditioned the engine 1000k's ago... since removing it from the car we overfilled it with engine oil to preserve the internals, and have regularily turned it over by hand (which is quite difficult due to the very high compression throughout the motor, we never got the oportunity to do a compression test, as we took it out of the car straight away, but it would definatly be well over 150psi/cylinder), to keep everything in its condition... we also took the camshaft covers off to get a picture of the internals of the head to show just how clean and perfect this engine is.
engine comes complete with the following:
polished everything (CAS too, which is not pictured)
new adjustable cam gears
new gates racing timing belt
new 5puk heavy duty clutch and flywheel machined
standard turbo's with insignificant shaft play, still plenty of life left in them
altinator, starter and power steering pump, all in perfect condition
standard coils, complete engine loom, coil loom and engine sub loom... (ignitor is included but not pictured)
standard diff included in sump...
also will include the standard front pipe (in good condition)
new seals and gaskets
there is probably more, but thats all we can think of at the moment
engine is located near kyogle NSW, we can deliver it within a 3hr radius too you for an extra $100
please note our price is cheap, as we need the funds for other priorities, and sadly this has to go...
price $7000 cash firm, please understand that we know there are other engines around at the moment for less, but we guaretee they are no where near the quality of this one. cheers
also we are aware that some of the pictures are missing the oil cap (only off for 1min till we put the standard one back, as we were trying to find a nismo one, but didn't, also some things arn't bolted down, but will be before it is bought... also we do have a gearbox from a 1992 r32 gtr with 60,000k's on it, which we could sell with the engine for $500 more or $900 seperatly...
Edited by sebastion
Guest
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
