  • Replies 521
Ken my bestest friend old buddy old pal ......
Can you get my: - Electronic boost controler for power fc.
You know the car details - here is the serial no. of power fc if required.
s/n - PFC ecr33 010-1563
cheers
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1856981
Hey boys currently overseas but now have wireless to the net so can keep up to date! Just wanted to let you know nuffin werks that camp smitty is a frezzing shit hole at the moment.
Also Ken can you get a hand controller for a power fc as i've already got the comp just need the hand controller for dyno tunes? If so how much?
Cheers stevo
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1868931
hey efteoh, jay told me something about you reckon its easyer to remove the head to get the No.6 exhaust manifold studs out.
Sounds like a lot of hard work and dollars. Is there anything else you can recommend to remove them. and getting standard ones from say nissan etc should be fine yeah as a replacement ?
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1907262
Well for those interested , i found the perfect tool on thursday to drill holes in the exhaust manifold studs that were broken off so i could get the screw extractors in to remove the studs. Anyway it cost a little bit for the tools etc etc but well worth it to not have to remove the head just to remove one stud.
The project is well underway with only a few more parts still in transit (frieght is so shit here) and the Whale will be back on the road again.
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1925726
  • 1 month later...
  • 3 weeks later...
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
