  • Replies 521
Ken my bestest friend old buddy old pal ......
Can you get my: - Electronic boost controler for power fc.
You know the car details - here is the serial no. of power fc if required.
s/n - PFC ecr33 010-1563
cheers
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1856981
Hey boys currently overseas but now have wireless to the net so can keep up to date! Just wanted to let you know nuffin werks that camp smitty is a frezzing shit hole at the moment.
Also Ken can you get a hand controller for a power fc as i've already got the comp just need the hand controller for dyno tunes? If so how much?
Cheers stevo
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1868931
hey efteoh, jay told me something about you reckon its easyer to remove the head to get the No.6 exhaust manifold studs out.
Sounds like a lot of hard work and dollars. Is there anything else you can recommend to remove them. and getting standard ones from say nissan etc should be fine yeah as a replacement ?
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1907262
Well for those interested , i found the perfect tool on thursday to drill holes in the exhaust manifold studs that were broken off so i could get the screw extractors in to remove the studs. Anyway it cost a little bit for the tools etc etc but well worth it to not have to remove the head just to remove one stud.
The project is well underway with only a few more parts still in transit (frieght is so shit here) and the Whale will be back on the road again.
https://www.sau.com.au/forums/topic/30197-darwin/page/18/#findComment-1925726
  • 1 month later...
  • 3 weeks later...
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
