As described, One 24mm Whiteline 3 way adjustable FRONT sway bar to suit R32 GTS-t for sale.
Will significantly improve handling. All mounting hardware included ( D Bracket things and Bushes)
After $170 non negotiable. Prefer local pickup in Adelaide only...
PM or ring/sms me on 0438 86 08 07
Thanks
Edited by R32Dreamer
