R34-Daz Posted January 1, 2010 Share Posted January 1, 2010 (edited) Before anyone starts, yes I barely know anything and yes I have gone back and read other posts. I found this video on youtube ( ), this guy has a custom built 2.5" mild steel mandrel bent, high flow cat, high flow resonator and high flow muffler with 4" tip, and it sounds pretty good.so what i wanted to know was, will he gain much? and if you change the tip into a canon will there be a dramatic difference in sound, like a huge difference? Edited January 1, 2010 by R34-Daz Link to comment https://www.sau.com.au/forums/topic/302078-na-r34-exhaust/ Share on other sites More sharing options...
SHANE666 Posted January 1, 2010 Share Posted January 1, 2010 You will gain a little bit of power going from the stock R34 N/A exhaust which I think is 2" in diameter to a mild steel 2.5" exhaust. You will gain a bit more power if you have an aftermarket exhaust all the way through from the extractors to cannon. High flow cat and resonator will add to the performance. Dont expect wild gains with this setup alone though. The cannon solely will make very little difference to performance, you will most likely gain some rumble! Link to comment https://www.sau.com.au/forums/topic/302078-na-r34-exhaust/#findComment-5011598 Share on other sites More sharing options...
{Oo{34}oO} Posted January 1, 2010 Share Posted January 1, 2010 gettin lots of noticable power outta an N/A costs lots n lots of money... unless ur aiming to get as much power as possible outta the car then just have a nice 2.5", mild steel, mandrel bent cat back with a big tip or cannon... doin stuff like extractors n hi - flo cats costs abit more for not much real benefits unless ur squeezing power outta it Link to comment https://www.sau.com.au/forums/topic/302078-na-r34-exhaust/#findComment-5011753 Share on other sites More sharing options...
R34-Daz Posted January 2, 2010 Author Share Posted January 2, 2010 Thanks for the help guys, now I know what to get/should get rather. Link to comment https://www.sau.com.au/forums/topic/302078-na-r34-exhaust/#findComment-5012906 Share on other sites More sharing options...
KezR33 Posted January 2, 2010 Share Posted January 2, 2010 Out of curiosity, how much does the stock cat restrict flow? When doing a catback system is it worth putting a high flow cat in, or will the main restriction be further up with the extractors/front pipe? Link to comment https://www.sau.com.au/forums/topic/302078-na-r34-exhaust/#findComment-5013110 Share on other sites More sharing options...
{Oo{34}oO} Posted January 3, 2010 Share Posted January 3, 2010 all i noticed was it made it drone 100x more lol... its pretty pointless doing a really hi-flowing cat back n leaving the extractors stock as yeh they will be more of a restriction than a good stock cat Link to comment https://www.sau.com.au/forums/topic/302078-na-r34-exhaust/#findComment-5013909 Share on other sites More sharing options...
Jack- Posted January 3, 2010 Share Posted January 3, 2010 ^^ pretty sure the standard is 2.25" I've done extractors, high flow ressy, high flow cat, 2.5" mild mandrel bent steel with a 3" tip. Downlow power is the same but once it hits the higher rev range, around 3000-4000rpm it takes off compared to before Cost me around $2,500 including DKNE extractors. Link to comment https://www.sau.com.au/forums/topic/302078-na-r34-exhaust/#findComment-5014418 Share on other sites More sharing options...
