Genuine Koya Driftek rims-new/never fitted-no scratches,scuffs,etc at all-metallic light gold colour
Bought them wednesday 23/12/09 for $1174 & have original receipt-just got some cheaper 17" rims the same size so these are up for grabs
Multistud rims-will fit either 4 or 5 stud hubs with PCD of either 4 x 114.3 or 5 x 114.3
Two 17"x8" offset is +34
Two 17"x9" offset is +35
They fit inside r33 gtst gaurds & clear the front turbo brakes without spacers-i had a 2nd hand pair of these awhile ago
Will definately fit Nissan r32/r33/r34 skyline's & silvia's with 5 stud hubs
Should fit any car with 4 or 5 stud hubs with PCD of 114.3
Can send with Australia Post or Courier[TNT probably]at buyers expense
Pickup from Maroochydore Sunshine Coast QLD 4558
If sent they'll be packed in original carboard boxes with extra thick foam & cardboard to protect the outside of rim/paint
Might trade for a set of 18's that would suit a r33 gtst with 5 stud hubs/PCD 114.3
Something like Lenso D1R's or the Koya copies of Volk GT-C's
I'm chasing $950 serious offers considered
post-59075-1262325753_thumb.jpg post-59075-1262325815_thumb.jpg post-59075-1262325860_thumb.jpg
From sunshine coast 4558 to adelaide 5093 with aussie post is approx. $140
A courier service would probably charge twice as much
Dimensions...55cm x 30cm x 55cm
approx 10 Kg's each
From sunshine coast 4558 to adelaide 7306 will be approx. $200
according the to aussie post website
I'd take them in & get it checked before sending
You could get a qoute frome a courier service like TNT but it will probably be a lot more
Dimensions of eack box...55cm x 30cm x 55cm
Weighs approx 10 Kg's each
Also have these to sell alltogether...
VGC dark bronze alloy JDM "Black Racing" Pro N1 Jap rims-thin six spoke-just a few very light scratches & one rim has some minor gutter rash in a few spots,not all the way round lip of rim-no centre caps
Rare cause they stopped making these years ago apparently
Two 17x8 +38
Two 17x9 +38
Two brand new/unused Federal 595 performance tyres-both 255/40/17 [cost me $180 each]
Perfect size for the rear of skyline r33 gtst's
And two used Sumitomo performance tyres both-235/45/17
Both with 85 percent tread
Perfect size for the front of skyline r33 gtst's
One is evenly worn
One is slighty more worn on one side
No buckles,flatspots or cracks
$1200 for rims & 4 tyres
I'll consider trades for either set of rims im selling
After 18" rims in VGC with at least 50 percent tread on tyres
I'll chuck in a set of new/never fitted "KKR" Forged Aluminium wheelnuts with the Drifteks or other rims I'm selling
...if sold today!
1.25mm pitch-only weigh 400 grams-about 1/3 the weight of standard ones
Dark grey/graphite colour
Perfect size for Drifteks
Paid $80-will sell wheelnuts for $60
post-59075-1263338625_thumb.jpg post-59075-1263338941_thumb.jpg post-59075-1263339002_thumb.jpg
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
