hi guys, anyone have experience welding stainless with a stick / arc welder?
ive done tafe courses and can weld with MIG, Arc and Oxy, and was going to go on and buy and train to use TIG, but currently I don't have the space for a tig welder and bottle
I want to make a simple tyre rack from stainless box section, and have been reading its possible to get decent welds with stick?
would be good to also know if theres any special requirements for this, types of rod and current required.
cheers
https://www.sau.com.au/forums/topic/302115-welding-stainless-with-stick/
Yes you can, they weld beautifully in the flat position, just make sure you use safety glasses when chipping the welds, the slag can pop out and land in your eye if not cleaned and wire brushed properly.
and dont get too close to it, slag got me on the nose! :woot:
ok are we talking about s/s stick welding or tig welding cause they are two completly different things stick weld looks similar to mig but tig welds are small and neat by the way why are you planing to use stainless steel anyway m/s is cheaper and will last unless u want to keep it for 20 years ?? thought youd like to know
+1
Unless you want to polish it or keep it out in the salt spray, mild steel is heaps cheaper, and will still last. If you're worried, paint the welds with zinc-it, and it will last. I have shelves I built over 10 years ago, have lived in moist garden sheds for the last 6-7 years and have nothing more than surface rust on the welds (I was too lazy to even paint the welds). If rust concerns you, you can always make it out of duragal, and paint the welds. Looks pretty enough, and will last a lifetime (just make sure you weld in a very well ventilated area)
I made a nice tyre rack that holds about 16-24 wheels / tyres depending on tyre width. It bolts together so I can flat pack it for storage.
Oh, ALWAYS wear safety glasses when chipping slag. I wear them under my welding helmet (helps that they are prescription glasses, so I can actually see what I'm welding now)
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
