  • Replies 164
Posted Images
SO i bought my first ever DSLR. These are my favourites from my first 500 photos ive taken in the first week ive owned the camera. Im super super noob so please add any constructive criticism but please explain with lotsa detail :( None of these have any digital touch ups or anything, just as shot.
So you're the one that bought Ando's car.. ? http://www.redbubble.com/people/samboaus/a...8659-10-the-s13
Negative. i still have my white 33 thats getting work done. My older brother Leif bought Ando's car and is selling his current s13.
One I took of my cat a few years ago :ph34r: I don't really do the special camera thing, the most I had was an old film Pentax SLR.. just on canon Ixus' now.
You can't see it (der) but I photoshopped some blue plastic out of the background.
The second one is just a collection of sunsets from the place I grew up.
Couple I did tonight just messing about.
Bit messy, need practice and a darker location *shakes fist at streetlight*
http://photos.jay019.com/random/
This may pose to have no actual relevance to the thread, or anyone here..but how do you actually do this?
I don't actually have a DSLR, or any photographic experience (apart from with a p&s) but this is awesome stuff!
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
