Hey guys,
Was out for a drive last night on a cruise, taking it easy. At one of the meet points, Ken34 and my cousine noticed that I had fluids leaking from the front of my car. At further inspection this proved itself to be coolant.
I drove it home cautiously, monitoring the water temp on the power FC controller, and didn't go above 85c at all. This morning I come out to have a look and see whats what, notice that the radiator is about half empty and so I start looking around.
I filled the radiator up with water (just to test, going to flush again later) and turned the motor over. Didn't take more than about 10 seconds and already the leak was apparent. Looks like it's coming from the water pump on the block. Now I'm not sure if it's one of the bolts (can't see) or if it's coming from the seal and leaking through the hole (which means it's stuffed, obviously). Not sure what to do here as I had her at Xspeed a few weeks ago and they did a full timing belt service on it for me, replacing the water pump at the same time. Is there any way I can stop the leaking for the time being or will I have to take it back to them sometime to get this resolved? Also, what are my rights in this situation being that the water pump is brand new?
-Chris
https://www.sau.com.au/forums/topic/302277-leaking/
How far from XSpeed are you?
Tighten the bolts as much as you can, and drive it with a few 1litre bottles of water with you and stop at service stations if you need to.
I dropped 80% of my water in Ozzy Park at the freeway on ramp, topped up, limped it home to Swan View and fixed it, wasn't too hard, just avoid stop/start traffic and main roads, if you do have to stop, you want to do it in a back road.
https://www.sau.com.au/forums/topic/302277-leaking/#findComment-5014026
Cheers Nic. I live in Palmyra, literally 5 mins up the road from Xspeed, so I don't think that overheating on the way there is going to be an issue hehe. Last night, I managed to drive from the meet point we were at, car park off selby st Osborne Park, back to my cousines place in Belmont. Then from there to my house in Palmyra, all without the water temp going over 85c. However this morning the water had drained to about half capacity in the radiator itself. I'll be able to get it there ok.
https://www.sau.com.au/forums/topic/302277-leaking/#findComment-5014122
Nah the guys at Xspeed are a good bunch. Hansons a great guy to talk to, knows his stuff.
Fairly sure it would be the gasket/seal between the water pump and the block itself. I'd rather just have the fellas do it however so as not to void any warranty or anything by doing it myself hehe. I was going to throw some fiberglass sealant stuff through the system today and hope it sealed the leak but decided against it as not sure how it'd affect warranty or anything.
https://www.sau.com.au/forums/topic/302277-leaking/#findComment-5014735
yes, kenr34 is an awesome guy
Haha.. This is the guy who noticed it was coolant ;) Mr. oz, I just gave him a rag to wipe his filthy hands before he got into my car!
We all thought it was oil at first haha I think your heart skipped a few beats.
Good to hear everything worked out ok. Was good meeting you on the cruise mate, we should cruise again once everything is sorted.
Peace,
Ken
https://www.sau.com.au/forums/topic/302277-leaking/#findComment-5015198
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
