High compression pistons, larger bore, balanced bottom end, stiff valve springs, aftermarket ecu, higher rev limit (assuming it is still making power)
with an na, you have engine capacity, head + ancilliaries flow, and rpm as your basics.
So if you had a 3.1/3.2L spinning to 7000rpm......
(going to a larger bore may not be a good idea, i dont know, im not an rb30e na tuning and motor building expert. its a good idea but i dont know if it will hinder the engines ability to rev or something)
my rb30e is getting a bit sick....
how much did each of your mods cost, who did it, what exactly is the mod, where is peak power, whats the powerband like etc???
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615498
the cam is a SURECAM (btw surecam make all the cams for chiptorque, and for the rb30 hp1,hp2,hp3 it's the same cam)
headwork was also done by surecam. double springs, lifter boxes machined, port-n-polish.
104rwkw's on the chiptorque dyno, power comes on strong 2500-7000
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615645
  • 3 weeks later...
without n2o or turbo!
Turbo is probably the best bang for buck though! can probably pick up the bits you need for under $1k, and run low boost (6psi or so) on standard n/a block without too many dramas.
or the twin cam head conversion also (may as well get a turbo head put on if you're doing that).
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-638082
  • 3 weeks later...
let us know how you ran at willowbank?? i heard something about a 15.2 or something worse then previously..
went to willowbank and only got one run in. there was a huge storm and the event was cancelled. heaps of wheel spin and ran a 15.3.
got it tuned at chiptorque, not a lot more power, a little more topend.
the single afm is the holdup, once i get enough $$$ i'll install a mircotech.
with this setup as is i should be able to run quicker than 14.8, but with the tt/b's i have lost some bottom end power so i'll need to change diff gears....maybe
next time i go out to the track i'll put on some 14's and run standard rear suspension, should help the traction probs.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-666976
not enough!!!
it was only 4rwkw's, the total cost of the tt/b's was $200 plus dyno tune. so about 400 all up!
i really need to piss off the standard airflow meter! i was thinking...hole in the bonnet, round air filter, bonnet scoop.
BTW......for those that dyno there car in 3rd gear, i made 108rwkw's in 4th and 128rwkw's in 3rd.....
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-667165
4rwkw?? that's bugger all! I've seen way bigger improvements with an XF throttle body conversion than a twin throttle setup. How was your torque? improvement? I noticed more torque with the a twin throttle setup then outright horsepower. but then again, I think the twin throttle setup is more wanker factor than anything. When you going out next?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-675743
Had my car dyno tuned (again) on the weekend. Told the operator to do a run in 3rd gear and another in 4th gear, made 1-3hp difference between the gears (less hp in 3rd). Don't know where you get an extra 20kw from changing a gear?!?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-678908
i had it dyno'd at chip torque by Lachlan Riddel (the owner) so ring them and ask him.
Should take the car down there just for a couple of power runs and get a comparison. I was told it's more than likely the way the dyno has been calibrated.
Anyway, I've been told not to reveal my hp figure but I'll be honest with you, we did loose hp but we always knew we were going to with the mods we did.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-683815
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
