  • Replies 201
Posted Images
whos details do you need Krishy?
This event will be discussed at the SAUSA committee meeting tonight. We will be having a display there, so lets get in early and start registering interest.
Ill be there.
Even after starting this thread to raise awareness, i haven't even entered yet. I then thought about not entering at all, I then realized i have the day off work, and its only $20...so i am in, going to fill form in tomorrow :(.
Im just filling the form out now and is just the $20 that i pay or do i pay for the Additional All Day Pass ($5) aswell, or is that just if someone else is tagging along with me?
The $20 covers you and a passenger, so the $5 would be for a second passenger. straight from the form: "Judged: $20 / $30 after 1/03/10 (includes vehicle, driver and buddy pass)"
