As per the title name, a mate bought some Federal 595RS semi slicks in the abovementioned size for his HR31, another mate reckons that a 40 profile is too small for the 9.5 wide rims he runs on the rear. He does have other rims if this is the case, anyone know one way or another?
Why would a 40" profile be too small for a 9.5" wide rim?
And what brand of semi-slick is this....you might be able to check tire rack or similar:
http://www.tirerack.com/tires/Spec.jsp?mak...tirePageLocQty=
With a A048 235/45 is designed for a 9" rim at most, a 235/40 might make it on a 9.5" but I think you'd want to go 245 or 255.
I'm aiming for 255-40-17 in a non-semi slick.
little skinny for a 9.5in rim. I've had that same size on a 9in rim and it was fine. It's only 1/2 inch diff. Just give it a go. Depends what they want though.
I think what he means is that a 40 profile won't stretch that much.
Yeah was a little unsure, of course its illegal lol, and well 235/45/17 tyres don't seem to be too stretched on my 9.5" rims, was more of a concern about the bead rolling off the rim. Car's not really going to be used for any serious track work or drifting, more of a quick street car.
The 235/40R17 Federal 595RS and/or 595RS-R is recommended by the manufacturer to be fitted to wheels 8.0" - 9.5" wide, so there shouldnt be any problems fitting these tyres to your wheels.
However, they may look a little stretched and will have almost no sidewall flex - ideal fitment for a 17x9.5 would be 245 or 255's.
595rs and rs-r and not semis, just sticky road tyres.
ya not sure about stretching 40's that much. federal do a r17 235x45 tho.
595RS and 595RS-R's ARE considered semi-slick tyres, not only by the manufacturer but by CAMS (Confederation of Australian Motorsports).
The term "semi-slick" simply means that the tread pattern has a lower void ratio than that of a "normal road tyre".
You are probably suggesting that these tyres arent "R-compound" cut slick tyres - and you would be correct... The 595RS-R is not a race compound tyre, however it has a softer compound than normal road tyres and a reinforced casing that is specifically designed to resist folding under extreme cornering loads - making it perfectly suitable for track use.
I hope this clears up any confusion :D
you may have to find a good tyre fitter as semi slicks usually have a stiffer sidewall, so they are harder to stretch (especially if they are new), and a 40 series will have a pretty low sidewall... so low and stiff sidewall = difficult... but hey, worth a try. i know of someone fitting federal 595 215/40/17 to 17x9.5 and 17x10... i think they had to use the brake cleaner + lighter method though. damn good stretch though!
it does, thanks, i thought the term 'semi slick' was synonymous with r-comp tyres.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
