can someone please help me i have just purchased an R33 (2 days ago) and am having some major dramas ,when driving the car at any speed off boost the car will just shut down like someone had turned the key off it is doing it very itermintently like it has a mind of its own drove it home from where i got it had the typical breaking down (shit coils) but was fine if you eased into not just stand on it i filled up at BP and the trouble started thought i may have got a bad tank of fuel ,so got home sucked all the fuel out and put in a fresh batch from caltex ,she ran fine till last nite now it is missing a farting bloody thing kangaroo hops when it shuts down no power at all doesnt backfire doesnt make any strange noises it is just like i have reached down and turned off the key (all warning lights and gauges still work) it will then pick back up gp another 2 or 300 meters and do the same thing this is my very first skyline and i dont want it to be my last ive made the switch from a V8 16 yr history to something different and not as thirsty SOMEONE PLEASE HELP ME
https://www.sau.com.au/forums/topic/302675-please-help-asap/
sounds like an airflow meter thing to me, check it is connected properly and that the connectors are clean of the old green cancer. After that im sure one of us can lend you an AFM to check to see if that cures the problem
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
