The odometer went a bit funny about 10 years ago. It says 480,000km, but it has only done 200,000km
I've heard of odometers stopping (especially on R31's) but has anyone run across this situation with an R30?
JohnH
https://www.sau.com.au/forums/topic/302963-high-odometer-reading/
If the odo says 480xxxKm, there could be a couple of reasons as to why papers state 200000Km. Is that what you're saying - clarify?
Cluster been replaced?
Engine been replaced?
In this case, the owner/seller has had the car for over 20 years. They're saying that the odometer is faulty and has clicked over 480000Km when the car has only done 200000Km. Car is in original condition, no engine or cluster replacement. I haven't seen any papers (or the car) yet.
JH
Or the car has done 480,000 km... seems like the likely explaination to me... :D
Pics of the car are linked below if anyone has time to take a quick look and offer an expert opinion:
http://s812.photobucket.com/albums/zz46/bwimbush2010/
200000km or 480000km?
And yes this car does make GTR30's car look good! (Congrats on the sale BTW)
JH (looking for a parts car - obviously many of the panels on this car are no good)
cheers JR...
there could be a couple of reasons..
1:
are there standard size rims on the car?
my car's overall size had changed from the factory one and i have noticed that the speedo was out (higher reading by roughly 10km per hour) which over time will give you a higher odometer reading like mine has. Have checked this on a dyno to an actual speed reading so my car has done less than it shows
2:
another cluster has been put in
3:
the seller is lying about the actual milage
cheers JR...
1:
2:
3:
3: Seems more likely to me
Car looks closer to 480k than 200 by the pics provided
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
