Its been a hard decision to make but I cant afford to spend any more money on my car and need to part it out.
Apart from the Turbo kit everything listed here is practically brand new. I had only just finished installing this stuff on my car and was in the process of getting it dyno tuned when we ran into problems.
It was either pull the engine again or walk away....
With the tune only ¾ complete this combination of parts made just over 300rwkw...
All parts have come off an Nissan Skyline R33 GTST (Series 1) and are located in brisbane & everything listed is still currently installed in the car.
300+ rwkw Turbo / Intercooler / Intake Kit - $5000
ok this will suit someone who has a fairly standard car and is looking for big power.
I made just over 300rwkw with this setup and want to try and sell it as a complete set. This kit is made up of a combination of new and 2nd hand parts.
If I don't get much interest I'll consider separating the parts at a later date.
  • HKS 3037 56t .86 Turbo
  • HKS Standard 50mm External Wastegate
  • Custom Exhaust Manifold – Ceramic heat coated
  • 3.5' split dump pipe.
  • Q45 Throttle Body
  • [NEW]600x300x76 Hybrid Intercooler
  • [NEW]Trust Type R BOV
  • [NEW]Genuine Greddy Intake Plenum – Powder coated Black.
  • [NEW]Custom throttle cable to suit relocated throttle body
  • [NEW]Custom intecooler / intake piping to suit
  • [NEW]All Hoses / Clamps / Silicone Joins to suit
RB25 Head - $1400
This was only recently reconditioned and reassembled by Colin Lloyd Headsense. Again I want to try and sell this as a complete setup but may consider separating at a later date.
All components are basically brand new and have only been used for a total of 6 hours on the dyno since rebuild.
  • Tomei 256 8.5mm cams
  • Tomei 8.5mm Valve springs
  • New guides & Retainers
  • Ported intake and Exhaust
  • HKS CAM Gears
  • Cam covers have been powder coated gold
  • Greddy Oil Cap
Power FC & Hand Controler - $1300
practically brand new – only just installed and used for a total of 6 hours dyno time.
Kakimoto Regu 06&R Exhaust & 100 cell high flow cat - $1000
Apexi AVC-R - $400
Oil cooler Kit - $250
ISC Radiator - $250
Set of 6 Nismo 740cc injectors - $700
Q45 AFM - $200
2nd hand but in excellent condition
Z32 AFM - $250
Comes with Tomei plugs - practically brand new – only just installed and used for a total of 6 hours dyno time.
More items still to come.
If anyone wants to make an offer on the whole car complete send me a PM.
Photos to come...
https://www.sau.com.au/forums/topic/303068-many-r33-performance-parts-300rwkw/
  • Replies 40
auto or manual, thats if ur selling your box
Its a Manual...
I want to get rid of it all so gearbox is up for grabs... If it makes a difference im pretty sure its a series 2 box as when i installed a short shifter the bush i needed for the end of the shifter was a series 2 part...
Its bolted up to a Jim Berry clutch (specd to 350rwkw) which is also new except for the time spent on the dyno...
PM me an offer...
Because you have not listed it i take it the bottom end is not for sale ?
Bottom end is the only unknow at this stage. During the dyno run we started to get a very slight bottom end knock at about 4000rpm...engine was shut down immediatly and hasnt been started since...
Bottom end has a brand new set of ARGO rods and CP forged pistons...Won't know what condition these are in until i get them out....If they are fine they'll be up for sale also...
Would like you to contact me regards bottom end 0437123233 when outcome is known.. Regards the complete cylinder head, 740cc Nismo 's and oil cooler kit for the agreed value of $2100-, then time is ok with me as no rush. I would like to send $500 as my deposit and confIrmation i am the real deal ! Just send bank details and i will deposit into your A/C . Also let me know if plenum is to be sold separatly ? , if not already sold ! Cheers Mike
Just been down and taken a few photos of the parts on the car. I've got a couple of days off now so tomorrow is the first chance i'll get to start removing parts. If anyone see's anything in the photos they want that isnt listed just send me a PM with your offer...
http://picasaweb.google.com/leigh.munro/Skyline
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
