I just got a set of HKS coilovers secondhand through the jap auctions and they look practically brand new but unfortunately the spanners weren't included.
I've also currently got a set of Tein coilovers which the car came with. Do I need the TEIN specific spanners to remove them???
BTW I'm selling the TEINs (off an R34 GTR, I believe it'll fit R33's also) if anyone is interested please feel free to pm me...
https://www.sau.com.au/forums/topic/303118-new-hks-coilovers/
The spanners are only used to adjust the height of the spring perch, all you need is a socket set to remove the actual coilovers themselves.
I sourced a new pair of hks spanners through an importer for about $50 shipped when I got mine, think it was perfectrun or greenline (cant recall which) & they just got them straight from hks. Generic ones will fit though.
Good choice with the hks too.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
