  • Replies 154
Its a awesome game, im a big fan of Final Fantasy series, but i found 13 to be too passive, all you do is go from A to B, but apart from that its got a good storyline which makes the game.
but still FF10 holds its number 1 position in my books =)
FF8 was the most epic out of all of them. Wicked storyline, awesome game-play, unparalleled diversity. I remember i clocked up a good 90+ hours on that game through high school.
Hell, i started playing it again not long ago. Bought it off the PS Store for like $12.
On another note, i just rocked upto the Orphan Cradle in FF13. Almost finished the main storyline.
yeh they have been goin downhill fav was 10 :)
Agreed, final fantasy is all bells and whistles now. The best ff games are the snes ones, 3,4,5,6 have the best stories. 8 was amazing. Then they slowly became a little dated. FF13 looks good but then again x-2 looked good LOL and it was horrible.
Play cronotrigger and crono-cross (awsome)
different summons,
ff9 had a bizzare summon system. Different stories, all based around the crystal though..lol some things never change.
Its a shame the FF8 summons did not all see there way through to FF10-13, pandamonia, siren, doomtrain, brothers and diablo are the best!!!
there are other RPG series that play alot better than the FF series though with far more engrosing stories.
Edited by oh-so-swift
Ok so it arrived yesterday and I got in about 4 hours or so...
It seemed rather linear the whole time however it moved you to where you needed to go for all the cinematic experience and to familiarise you with the world, the fighting and mobs on the path etc.
At hour 3-4 I became a l'Cie... suddenly combat got fun then by the 4th hour they added Paradigms. I dunno what people are whinging about I am quite happy with the eye candy and baby steps into the world. You can tell they are slowly increasing difficulty as they push you into the story...
I just got a ps3 and got this game, havnt played it yet it looks amazing. Cannot wait. Funny enough i heard that when ur lvlin up your characters if you see two different types of creatures they battle each other everywhere which is funny as. Cause you can be close enough, enjoy the fight, then kill the weakened creature and collect the drops/exp.
MSTRshenanigans
I'm enjoying being able to see and run from encounters where needed!
That's always a plus. Wonder how well they have done the gameplay with the summons.... Cannot wait to play it 2nite and find out.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
