  • Replies 197
hey guys haven't been here busy busy :S... meting up this wednesday??? i should be able to come donw aswell... so ye 7:30 same place??? i saw a few R34's around the area i wonder if they are on the forums too???
I was up in the carpark out the front of Harvey Norman, where it has been all along. Lol.
I should have wandered down to the coffee club. Do you have a pearl white sedan? Where dd you park?
Yeah that's mine, was parked out the back of the coffee club, should have read the thread more carefully. Next time i'll park at HNormans.
You guys need to sort your shit out :(
Park where you meet. No point having two spots where people might be. I think that's why ours works so well is that our cars are parked in front of us the whole time. So anyone else who rocks up, we see them, or they see us. No one is wondering "where the hell is everyone?"
