hey there, been searching but couldnt find anything though whats the max camber on the fronts and rears of a r32 gtst stock arms.
also while im on the topic of suspension, are r33 lca's a straight fit into an r32 model or is there any modifying?
cheers guys,
Edited by silbastian
I don't know the stock camber on the front and rear at stock height. It varies depending on the height of your car a little.
My car is on TEIN Superstreet suspension wound as low as they go, and the fronts are reading about 1degree, twenty something minutes each side.
The rear on the other hand is a bit over two and a half. I'd really love some adjustable arms to fix this up.
The R33 front LCA's I've been told will fit, and will give you a little bit extra lock and also a bit more camber. Yet to try it out though.
Edited by -Jimmy-
as said camber will depend on ride height
im pretty sure std front will be around 1.25 deg neg
r33 LCA do fit straight up to r32 i had 2.5 deg -ve once they went on with a ride height about 345mm i think
rear you add camber pretty quick as u lower the car
cool thanks for your input guys, helps heaps! yeah i just realised the height of the car factors in aswell.
im running r33 lcas and have around 2.5 degrees at the front. The rear is set about the same height and is at 3.5 degrees. This is with all non adjustable arms..
nice, got any pictures if you have taken any?
i have r33 control arms... they are straight fit. they can give anywhere from 2.5 to 3 deg neg camber, depending on height.
the stock arms are not adjustable, how it is is how it is... and camber will be should be neutral at standard height.
to change the camber you'll need adj arms or offset bushes..
alot of people are running r33 lcas as they push the track out 15mm more, allowing wider wheels, and more lock..
sydneykid says these hurt bump steer and doesnt recommend doing it, instead change the camber at the top arm only, or set the the top arm 15mm out to push everything out and then adjust camber from there.
  • 3 weeks later...
sorry meant ball joint.. the 33 joint is thicker than the hub on the 32 so just press out the 33 ball joint and replace it with the 32 one... i have fitted 2 sets of these to both my current car and my first 32.. i figured this out the first time when i realised it wouldnt fit
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
