  • Replies 45
If there's no crash history, I might just take the whole shell + black interior you're willing??
Otherwise, can you find out how much approximately to ship front + back seats + door trims + glovebox lid thing (assuming they all match)
Edited by Nic_A31
why are you wrecking it? , complied shell? . what colour is the trim? cheers
its was a parts car when i bought it (we have 2 other ceffy's) and i bought it as a statutory right off so cannot be road registered. also the plates have been cut out of the engine bay so dunno how that effects things but at least theres no real structural damage so can be repaired as a track car.
trim is black with the cord style interior (not the suede).
after the following
-clean crack free dash
-passenger airvent and surround or just surround
-stock gay grill to cut up
-stock ceffy side mount with piping or FMIC
dash is available for $100 (includes dash top which is pristene, and surround for the instrument cluster, though this has one vent with a broken support - not visable but means the vent doesnt stay where you aim it at)
Dont have passenger vent surround (still after 2 myself, lols), grill gone already, as is the side mount.
front seats in good nic, bottom half of rear seat in good nic also, top of back seat faded around top and small top tearing around seams. all matches plus entire glove box as well (no trans surround and radio facia) also 4x door trims also matching trim, drivers side has wear mark near switches and elertic window switch has aesthetic damage. passenger front has loose pocket lining, others all good condition but all have slight fade. sell for $250 plus shipping, dunno what courrier would cost to perth, but that would all have to be arranged for at your end please. will transport them to courier in adelaide if a must but pick up preffered (i think it costs about the same)
i cant PM yet, so PM me your email and i can send u pics.. that goes for everyone :banana:
hook us up a deal on all four door trims and dash and ill organise my own couriour to pick up
Door trims are on hold for someone, but dash is available for $100 (includes dash top which is pristene, and surround for the instrument cluster, though this has one vent with a broken support - not visable but means the vent doesnt stay where you aim it at)
If the door trim guy falls through i'll let you know.
Courier can pick up from 5155 (Adelaide Hills, SA)
castor rod brackets, what the castor rod/radius rod mounts to. Bolted onto the chassis up the front... Also the sway bar D-bushes mount to it.
Available and price.
Thx
Edited by works 510
Thx
oh now im on it, sorry mate, need them for my car
Has the boot got all the trims/lining inside still?
And also the little trims that go over the back of the seat rails?
got all boot trims $65 i THINK its got all 4 seat rail covers... you mean the little plastic things that hide the bolt? its def got the drivers 2, not sure bout the other 2 as that seats been taken out... will have to scrounge thru the car (its not here atm) but $15 for them. are you SA? can you pick up?
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
