Thought I'd post a couple of pics. My car has now had all visible rust removed with lots of new steel put in it's place. These pics are at guide coat stage, and it is smoooooth. Near all imperfections gone. New steel welded in around the boot, that strip that holds the boot rubber in place.Should be finished in two weeks. New colour: Bondi Bleach. New number plates: BLEACHED AS
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/
The job so far. Also all other bits like flared guards, light surrounds and garnish are gloss black. Pick it up on Tuesday and should be assembled by Thursday. Then it's off to Bali, me that is for 6 nights.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5052452
i dunno man i
d [refer to see you do an engine swap with an RB rather than a v8. but you know that's just my taste. i have an RB20 in my silvia (around the same weight) and i tell you... it goes hard as hell!!!
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5053979
Hi Drew, yeah I still want to swap something into it. I just know the L28 isn't going to give me the HP I want. It has to be boost or V8. V8 seems the easiest as there's no injection to set up and I have the go ahead from the Dep of Planning and Infrastructure here in W.A. I love V8s' and love me coupe, so? That 210 at Jollys' has the RB30 in it, now if I could get the relevant bits and pieces, mounts, gbox crossmember, I'm assuming it's had a RB box in it and that's why it's gone. Plus any special looms that have been made up, this could alter my thinking. I just want easy or easiest.
ANYBODY WANT TO TAKE A LOOK AT IT FOR ME? I pay by the hour. Message me if doable please.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5054647
Geez Ricky
I don't think a V8 would be a good idea mate.(IMHO)
L28 with tripple webbers would sound so cool with plenty of HP and be in keeping with the rest of the package.
Failing that stick with an RB20 or 25.
Looks great so far :D
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5054841
Andrew, I actually have a friend who is trying to sell me a L28 turbo set up.54/P90 Microtech computer, sequential injection, brand new ball bearing turbo( large), motor is fully rebuilt, and comes with plumbing but to suit a Z. It's 8.5 compression and running low boost. Has already had 240hp@TW and is apparently good for up to 280 + some. Problem is the price, he wants my motor and another 8 grand, this is the installed price but it's just a bit exy. Would be nice to stick with a high HP old school motor.
Todat I'm going to compression test that 308, he wants $800 for it.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5055780
post-44326-1264678243_thumb.jpgpost-44326-1264678628_thumb.jpgpost-19495-1125201912.jpgStill needs a buff and the new rear flared guard put on. But the paint certainly improves it. I'll get the front springs cut to lower it a bit more soon. Oh and of course put the bumper back on. It's not a show car paint job, once buffed it'll look heaps better as it has a few blemishes here and there but it was noly $2500 and a lot of new steel went in to replace the rust and my patch ups. Overall I'm pretty happy with the outcome and it is the first car my mates painted in about 8 years.
https://www.sau.com.au/forums/topic/304138-rust-free-coupe/#findComment-5059034
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
