For Sale. PM me with offers
Will post anywhere, postage included in my pricing.
Stock 1993 R32 GTR ecu
$100
Apexi SAFC, 1st version, dial knobs, good condition
$150
Greddy Profec B spec-ii
6months old, barely used
$350
MAP-ECU
see here: http://www.mapecu.com/
$400
bargain.
cheers all, items located in Adelaide for pickup, pricing above includes postage/delivery tho
Tangles
these items pickup only
$100 rear wing, working light,
from a r32 sedan, silver
$200 rear seats, amazing condition, so so SO clean
front seats available too $100ea
I bought the map-ecu back last year, never turned up so I bought a aem fic/8
For the stagea
the aem f/ic-8 worked well for the stag, and then this map-ecu rocked up in the post just now
wired it into the gtr ecu, runs fine, laptop reads the program / ecu no worries
decided tho I'll be buying a power-fc shortly, along with injectors
Ive got the ecu manual, program, etc, but it is all on the web www.map-ecu.com
cheers
BUMP
anyone for a neat 5-star top condition r32 sedan interior, adelaide? $400 pickup all interior doors/seats?
map-ecu on ebay, need it gone http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
profec-b on ebay, need it gone http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
also got R32 rear wing, silver with light - $100 pick up
bump
southern adelaide pickup
rear wing, rear seatbelts, front seatbelts, rear seats, front drivers seats, front passengers seat
includes seat rails, all seatbelts - all in excellent condition. very very clean. smells new ;)
$300 pickup for the lot
need it gone, ta
profec B sold, sorry
4sale still:
r32 interior seats with seatbelts
map-ecu piggyback
r32 silver boot spoiler / wing
NEED to hold onto the stock ecu for a little while yet
sorry
as soon as I have the power-fc i will pm you re: r32 gtr ecu
