Wanted a V35 350GT when I was looking for a four door but ended up going with this minter local example instead.
One of the most underrated cars on the road:
- Has log book history ie serviced regularly
- No mods
- Leather interior
- DVD Player
- Polished and waxed regularly
- Detailed inside regularly
- Very Reliable car
- Genuine reason for sale
- Excellent Car
- From 2002 to 2006 (some say 2007 as well) the engine was voted amongst the 'top 10 best engines' by WARDS auto.
- Economical too
- Would prefer outright sale but if you would like to swap it with your car (or maybe other significant items such as a jetski, boat, etc) plus cash my way then please place your offer.
So if you like the look of the car come around for an inspection and see if you can negotiate a price with me...I'm pretty reasonable
Follow my link in my sig below for more pics (but will post some more)
Price: $16500 no RWC OR $17500 w/RWC
Contact: [email protected] or 0420453475
Serviced: Dan @ ERD
Thanks.
https://www.sau.com.au/forums/topic/304660-fs-2004-nissan-maxima-ti-l/
  • 2 months later...
Hi all,
Firstly) I'm thinking out loud here and putting out an EOI/SALE (again) with this car .....price will remain as range mentioned in post#6.
Maybe times are a bit better for some who are interested in this type of car unlike immediately at the start of the year.
Secondly) If you have swaps I will only consider a smaller four door car (up to the value of $7.5k) + cash my way (in other words I'm downsizing).
Can't edit my post.
Thirdly) All other important details are still correct as per above.
so please consider this car if you're after a luxurious family mobil
thanks
Paul
Edited by jaxt
going in for RWC tomorrow.
CARSALES LINK
the price reduction is for SAU members.
FYI.
Things done as part of preventative maintenance and repair for fair wear and tear since owning it:
- oil and lube change and top up every 5k kms inc important transmission fluids at 120k kms
- engine mounts
- cv boots
- power steering hose
- 4 new tyres
- Nissan factory recall air intake issue
- wheel alignment and balance
- polished and clay barred
hope this helps
My partner wants to sell her 02 Nissan Pulsar ST if you are interested?
Had a major service not long ago.
Just had a full inside and out detail.
Has a scratch and a dent or two. And 260,000km.
Still drives great.
  • 3 weeks later...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
