I am easy on all the prices so don't be scared to offer a better price. only if its serious of course.
Stock r33 gtst turbo never boosted over 8psi. i took it off the car when i upgraded. awesome condition - $100
stock r33 gtst exhaust manifold - $50
C.E.S RACING SYSTEM dump pipe to suit r33 gtst low mount turbo with wastegate pipe -$150
R34 steering wheel cluster (so indicators lights and wiper control plus loom) - $50
R33 LOCKED diff - $150
Cusco strut bar for r33 - $100
K N air filter was used on a gt35/40 so it has i think a 4" inlet - $50
r33 GTR fuel pump - $80
BRAND NEW SARD fuel regulator - $150
r33 twin gauge pillar mount - $80
4x r33 stock rims PLUS 90% tread on all 4 - $300
Trust / GREX oil cooler for r33 all braid lines hardly used. - $500
if you want i can load up a lot more pics on the items.
i will send if required too. i live at murrumba downs brisbane qld.
either email me at [email protected] or contact Kieran on 0430450805
https://www.sau.com.au/forums/topic/304890-r33-gtst-parts-for-sale/
i keep getting msges from ppl saying they want the cooler and reg but when it comes to payment they bail.. come one guys if you want them don't mess me around..!! these parts are brand new and cheap too..
  • 3 months later...
Hey fella - Do you have a regulator still for sale? PM if you do?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
