I am easy on all the prices so don't be scared to offer a better price. only if its serious of course.
Stock r33 gtst turbo never boosted over 8psi. i took it off the car when i upgraded. awesome condition - $100
stock r33 gtst exhaust manifold - $50
C.E.S RACING SYSTEM dump pipe to suit r33 gtst low mount turbo with wastegate pipe -$150
R34 steering wheel cluster (so indicators lights and wiper control plus loom) - $50
R33 LOCKED diff - $150
Cusco strut bar for r33 - $100
K N air filter was used on a gt35/40 so it has i think a 4" inlet - $50
r33 GTR fuel pump - $80
BRAND NEW SARD fuel regulator - $150
r33 twin gauge pillar mount - $80
4x r33 stock rims PLUS 90% tread on all 4 - $300
Trust / GREX oil cooler for r33 all braid lines hardly used. - $500
if you want i can load up a lot more pics on the items.
i will send if required too. i live at murrumba downs brisbane qld.
either email me at [email protected] or contact Kieran on 0430450805
https://www.sau.com.au/forums/topic/304890-r33-gtst-parts-for-sale/
i keep getting msges from ppl saying they want the cooler and reg but when it comes to payment they bail.. come one guys if you want them don't mess me around..!! these parts are brand new and cheap too..
  • 3 months later...
Hey fella - Do you have a regulator still for sale? PM if you do?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
