hey all
im more then sure this has been asked but finding it is a different story
can any one tell me what the out come would be if you were to touch the neg and pos of a 2.5 farad stereo capacitor at the same time with your hand
any info welcome thx in advance
https://www.sau.com.au/forums/topic/304915-25-farad-capacitor/
Dunno what voltage would be on the cap you refer to (could be 100vdc plus) but if there is enough pressure there to over-ride the resistance of your skin & deliver the stored current charge (which would be fairly hefty from a 2.5 farad tank), then it is gunna hurt. A lot.
Household RCD's/earth leakage/safety switches are set to trip at 30 milliamps, very quickly (in milliseconds) so that you do not get a sustained boot & killed. No such luxury plowing around in your stereo amplifiers' innards. Like all electric shocks, even if you haven't fried yourself outright, things can get out of wack as a result.....irregular heartbeat possibly leading to heart failure at a later time & so on.
DC also has the nifty trick of causing muscles to contract so that you often cannot let go of the thing that is biting you until it says so (discharged) or some nice person comes along & throws the switch.
Avoid it like the plague, take all precautions. My 2c.
Cheers GW
If you are talking a power capacitor running on 12V it's not going to harm you, just like a 12V battery won't zap you.
Just make sure you don't have wet hands if you touch it or metal objects that could short out the terminals to each other or the chassis. Too fast a discharge at 12V is the biggest danger as it could blow up in you face literally if you aren't careful, not that I have actually heard of this happening myself.
If you want to pull this appart I suggest you find out the best way to discharge it first, & then check it with a multimeter to ensure it's safe. If you are not confident seek professional help.
hey all
nothing will happen unless your wearing something metal, but these can be used for other nasty items. but wont discuss on here.
beware they can become hot when you first charge them without the resistor, and they can spark
no idea why you asked this ??
probably best if you dont put your tongue on it 9v battery style...
which made me laugh about the time I suckered a friend with a tongue piercing to do just that with 9v battery, funniest thing ever to see a spark fly off there tongue..hahahah I'm a sick bastard but it was funny
hey guys thanks for the replys
the reason for asking is friend has one in his car with exsposed terminals 12v system and would be easy to touch by mistake.
Just wasen't sure if it was going just give him a zap or cause severe damage like blow of a finger
i play with stereo's on a dayly basis (tuning) but never had a need for any cap to be placed in the system
sorry for the lack of info in my first comment
anything metal will spark and possibly cause a fire, cover the terminals somehow
    • You're already well into "gearbox is a consumable" territory there. A billet plate will either make it (effectively) 1% stronbger or make it last one more pass. At some point you'll probably tear 3rd gear into small chunks and regret all the life decisions that came before it.
    • ..and forum.r31skylineclub has been down all week....anyone know why?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
