so, thanks again paul. I un ticked all the settings and now parameters are shown in the commander.
regards.
the only problem is that now it starts but after 1 or 2 seconds i t dies :ermm:
After any change it was running good.
But, if i crank it and keep pressing and depressing the gas very quickly, it stays at 4000 RPM. It runs very weird ant extremely rich. And as soon as i stop pressing the gas it dies.
could it be beacause of the unlock i did?
thanks.
i would do this
save your tune
make sure you have a copy of it
make sure you have a backup of the copy
DATA INIT the EVO PFC
restart the car
do a READ ALL in datalogit and save the stock maps
then compare those to what you have, it might be something simple
i would do this
save your tune
restart the car
doing a data init would save the MAP sensor settings?
BTW, is it possible that the problem i'm having is due to a ECU issue?
Thanks.
no, when you do a DATA INIT, it will erase the entire tune back to defaults
the default map will be what apexi set the standard map on the EVO PFC to
hmmm....
so i'll have to use the map calibration saved in the map.
Thanks a lot paul, i'll try this and let you know if i get any good result.
BTW, what is that about a Tuner String???
Edited by chip
send us your saved datalogit tune, ill check it vs the stock evo maps
the tuner is string is from apexi fc pro and datalogit
its used to tag features in datalogit, ie anti lag and other junk
ignore it
ignore it
here's the tune.
http://rapidshare.com/files/379241498/evo_VII.dat.html
So this is a power fc PRO???
Thanks.
no, the term FC Pro is misleading by apexi. its covered in the powerfc faq in my sig
FC Pro is software apexi use to tune powerfc's.
the 1st generation of powerfcs were only tunable by the hand controller
the 2nd generation of powerfcs were plastered with silver "FC PRO" stickers on the side of the case and were tunable by the hand controller and software apexi made (and later sold to the public). the software is apexi fc pro and it lets you connect it to your computer / laptop.
the common misconception is that any powerfc that has the original silver "FC Pro" sticker on the side of the case meant that is an Apexi PowerFC Pro unit. this meant it contained 0km/h launch control and spark cut instead of fuel cut. The silver "FC pro" sticker acctually indiciates that you can connect it to the apexi's FC Pro software
Paul, thank you VERY MUCH mate.
I did the data init and it started great. It tooked some time for idle to settle down but it's runing great.
Map sensor scaling seems to be working fine.
No i just need to tune it.
Once again, thank you indeed.
PS: If i need more help i'll contact you :)
now that the car is working etc, you should be able to open your old tune in datalogit and do a WRITE ALL
to put the tune back to its previous unlocked state
it may be a datalogit bug where unlocking certain tunes mangles stuff
but the tune itself is OK, so if you save it, DATA INIT, write the tune back its all OK
if you have unstable idle read the PFC FAQ For self install
theres a 30 min self idle you are supposed to do when you do DATA INIT
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
