So my car just failed it's MOT test, the upper control arm bushes are gone. I guess that explains why one side was running -4 degrees camber and the other side +1 1/2.
So I need to fix this. I was wondering how to go about it.
So far I've found the following, assuming that R32 GTR bits will fit the suspension on my 4WD Ceffy
R32 GTST/GTR front camber arms
Reasonably-ish priced, but maybe too much NVH for a daily driver since they replace the bushes withbearings.
Whiteline camber adj kit, upper c/arm
Seems like the best option as I get polybushes so should be nicer to drive, and I get a bit of adjustment just in case it's needed. The downside is it's extortionately expensive and I'd have to keep greasing my nipples afterwards
Polyeurethane bushes
Should be fairly cheap and not too bad for NVH. The downside is that no bugger sells Upper wishbone polybushes for the R32 it seems.
Any suggestions?
Edited by Lum
  • 1 month later...
Over here on Adelaide, OZ, We have suspension places that do wheel allignments, shocks and replace all types of bushes standard and aftermarket.
Whiteline is a great option slightly expensive yes but you will find the poly not adjustments to nearly be the same price, expect few hundred installed but the car will drive so much better.
Good luck
Also here in australia we've got a manufacturer of quite a few polyurethane bushes, some even come as full assemblies with nickel-plated steel etc.
they have a part number for the R32 GT-R, front upper inner and outer control arm bushes, alignment adjustable, 45488.
Nolethane bushes are f**king awesome. www.nolethane.com.au
Nolethane are good, and they list a complete kit for front and rear for A31 Cefiro RWD, which is what I've got.
For the AWD models, just order R32 GTS4 parts, and any bushes immediately on the front knuckle assembly needs to be S13 (such as the bush between the knuckle and lower control arm, and the bush for the steering arm end).
Ended up getting the whiteline ones as I didn't want the NVH of the solid arms. The car passed it's inspection so I'm good for another 12 months.
that nolethane site doesn't seem to exist, or it's down at the moment, but will check them out when funds are looking a bit better.
edit: it's www.nolathane.com.au
Edited by Lum
You try catering for all the mechanics within a 500km radius (excluding metro phags of course).
I've just got a lot on my plate right now okay.. *starts twitching and crying*
  • 1 month later...
Should probably update this.
Went with the Whiteline R32 GTR ones since they were in stock and available next day at Demon Tweeks, bloody expensive for what they are but I can't fault their performance.
Got them fitted, passed the MOT, got an alignment. Guy at the alignment shop hadn't seen anything like it (the Ceffy, or the whiteline bushes), spent 10 minutes swearing at the bushes until he figured out how they worked then praised how easy they were to adjust :D
Out for a test drive, he throws it into a corner "bloody hell", he exclaims. "what?", "This is really nice. I thought it was going to drive like a barge and be all wallowey" *proceeds to throw it into the next corner at about double the speed limit for the road* "I think it's aligned right".
Car is driving better than ever now. Just had the sill fixed where some muppet in Japan has put a jack through it, now just got to find out why my front suspension has started creaking. Hopefully just needs more grease now the whiteline bushes have settled in.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
