anyone here would recommend Nisscare in royal park? thinking of taking my car there for a gearbox check... :)
yes, would highly recommend them. they've been looking after my Patrol's servicing / mechanical for the last 18 months. Top service, not overpriced and they know their nissans (and other cars too)
https://www.sau.com.au/forums/topic/305601-nisscare/#findComment-5055628
what you hear and what you experience are 2 different things mate.....you can hear good things about a place and then you go there and the experience is otherwise.....
best thing is to go there and find out for yourself as to what type of place/people/customer service they have
https://www.sau.com.au/forums/topic/305601-nisscare/#findComment-5056058
I had a clutch put in by them some years ago in an R31. A few months later i had to replaced the gearbox, i decided to do this myself and when i got under the car i found that they hadnt tightened three of the bell housing bolts. i wouldnt go back. Just my experience with them however we are all human and everyone has bad days at work.
https://www.sau.com.au/forums/topic/305601-nisscare/#findComment-5058930
they worked on my sisters car and we got them to check why it was overheating, the replaced the top tank of the rad and the thermo and never even looked at the water pump or asked us if they wanted us to get them to do it
a week later water pump failed.
so yeh NO, go jms or smooth
https://www.sau.com.au/forums/topic/305601-nisscare/#findComment-5058950
Hey glad you had a good run with them. I took my car to them for an overheating problem aswell after hearing nothing but good things. 2 young guys came out with a torch... looked at it for all of 5mins and said they couldnt do anything for it and sent me on my way.
Best of luck lol
https://www.sau.com.au/forums/topic/305601-nisscare/#findComment-5066149
    • I do like the look of these things (minus the ugly flat top surface with the text) https://rajabracing.com.au/product/nissan-rb25det-neo-intake/ Retains the OEM bottom runners, for that phat low range. If you want response king, maybe go with the Plazmaman pipe work, here's my old setup from a decade ago
    • Torque will suffer greatly, will try and find dyno difference on r34 with gt30 between stock and plazmaman short runner. like 2000-3000rpm power rdip at least. EDIT Green line is stock manifold, others is plazmaman short runner I also had a rb25 with greddy and q45 TB back in the day and was shit daily driving. Plazmaman top plenum with stock runner and DBW made it so much nicer.
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
