R32/R33 GTR Power FC and Hand controller = $699
Passengar S13 silvia door (blue) = $50
Trust power evolution II cat back and de-cat pipe for R32 = $599 ono
Sard Fuel Pressure Reg (used) = $99
Rear strut brace for R32 = $80 ono
Standard S13 silvia steering wheel = $75 ono
Blitz Oil cooler kit with relocator for R32 = $750 ono
SSR Gartimaier wheels 18x9/18x10 +38 (basically new condition) = $1799 ono
SSR Strusse wheels 19x10/19x11 +11 (centre's freshly powder coated black) = $1799 ono
Medusa wheels 18x9/18x10 -10 (centre's freshly powder coated black) = $1799 ono
S13 silvia second hand front ISC N1 coilovers (lessthen 100km old) = $550 ono
CA18det high flowed P/S pump cost $550 selling for = $249 ono
Used adjustable toe arms (2 sets) = $100 ono (each set)
Fixed back seat rails for S13/180sx etc = $100 ono
JIC GTR style reclinable seat (perfect condition) = $499 ono
Buddy Club fixed back seat (brand new) = $699 ono
Nismo 260kmph speedo R32GTR = $299 ono
RB26dett hard pipe intercooler kit = $199 ono
RB26dett generic front pipe (aftermarket) = $150 ono
Greddy Boost gauge (2 available) = $80 ono (each).
Turbosmart EBoost2 40psi 60mm (brand new in box) = $599
***Pictures available on request.
  • Replies 43
will the toe arms fit r34? are they rose joint adjustable? or do they have adjustable bushes?
if they'll fit r34 gtt and are adjustble bushes can i grab some pics?
Cheers
Cheers
They will fir R32, S13, 180sx, A31.
The only thing you will need to do to make them fit R33/R34 is to put some spacers in there as the rod end is a few mm smaller. Yes they are rose joint adjustable.
Bek
Hi interested in exhaust, not so much de-cat pipe tho as i have a 3 inch cat. could i have pics of exhaust plz :) also how much would it cost to post to yamba 2464?
Edited by DuFFR32
Pics below (just needs a wipe down). This exhaust cost's around $1499 new from Trust and is 3.75".
Bek
Edited by boostd_r32_gurl
pics pls
Bek
They are a good bit of gear, have one myself!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
