Torrent speed is limited by the seeders... if you dont have enough seeders = their max upload speeds...
With rapidshare (co-incidentally with hamachi network with other Internode users also) I was maxing my speed.... there is no way you can compare torrent to a direct DL. Especially when you are downloading from Aust sites...
well i'd thought i'd had it optimised as best as i can, i have a billion 7300g, best router I've used so far, got any tips ash?
Without looking up the router specs to match your torrent client - Nope :D
If i get bored i might. What torrent client you using?
Also ensure the latest firmware is on there, often that can make all the difference.
I max my speed out with torrents, i can have 10 people seeding to me.
It's not the number of seeders, it's the swarm speed that matters.
500 people upload @ 1kb/s on one torrent... yet 10 people upload @ 500kb/s on the next - guess which is faster :banana:
I can see the same speed via torrent as i can direct download from Aust sites.
Only issue with torrent is it takes 1-5 mins to register and "speed up" once links are created. Usually im running max in under 1min.
You don't always get a large amount of seeds to dls though...
500 x 1 or 10 x 500 :D
I dunno, torrents don't suit the projectw use so its useless to meh =D
Download skinnier chicks... they won't take up all the bandwidth
They might get hungry for some if you have it spare or worse yet they might have a memory leak :banana:
using utorrent, hmm well I remember back in the day having to create a static IP for my pc and manually setting up port forwarding on a linkysys router just to get torrents working properly, surely that's not going to make things any faster in this circumstance!
interesting comment about the firmware, I was under the impression that it wouldn't do much at all!
Ok 7300g
Max connections you want is around 750 or the router is going to shit itself much above that as it has around 800-1000 connection limit or there abouts.
If using utorrent you need to decide how you are going to download.
1 Torrent at a time - set max connections per torrent to around 650
More than one torrent - divide 650 by the amount of torrents you want to have running
There are some other things you can change, but im assuming you don't have any issues at the moment with drop outs and so on.
If you do, post up. I'll have the fixes for it :P
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
