Hi Guys...
I have spoken with andrew, and he assures me they're juuuuust about done: ready to go into the oven ( I assume for undercoating)...
Apparently we should expect them on our doorsteps mid February. He has apologised profusely for the delays so far, and said he'll be in more regular contact from now on (although exactly how much we will need to know in the next 2 weeks is a moot point...).
So, there you have it.
To anyone else who's interested, I'll be getting my kit fitted pretty much straight away: I'll post pics when it's done! :)
https://www.sau.com.au/forums/topic/305804-roof-rail-replacement-kits/
  • 3 weeks later...
Ok: just spoke with him again, and there will be a small delay (as usual): He has assured me he is onto it (we had quite a long and informative chat), and they will be ready ASAP - within the next couple of weeks. Patience, peeps!
I'll keep you guys in the loop as things develop.
  • 2 months later...
I have contacted Andrew again, as there was no word from him, and the kits were at least a week overdue after his last expected date.
Long story short, he is HOPING to have them ready for shipment mid next week.
Getting frustrated now...
Haha... It has been a very long ordeal. Im sure everyone including myself will be stoked once we get them. Have you had your roof rails out this entire time waiting for the replacments?
I chased him up 2 days ago as well
Stagman, we will get ours sent up togather to save postage.
I've had them off for over a year now: this whole thing started when another Gold Coast workshop stuffed me around for 7 months, after quoting me 2 weeks to modify the rails I bought from Japan.
Note to all who buy the kit: I discovered some light surface rust on the roof under where the rails sit, and am unsure (and doubt) if the original removal of my rails caused it: could be like the "rust under the mirrors" problem - if the rest of you guys find the same thing, then we can assume it's another common issue....
..Eeek
bugger!! maybe if these rails ever get made i better get a set so i have an excuse to check for rust
watch this space: mine will be fitted and painted as soon as I get them.
Guys
Andrew needs to know if your car has sun roofs, as they will need different mounting bolts to cars without.
An email has been sent to let him know
PS
My car had NO rust under the rails
  • 4 weeks later...
ok: He's finishing up the kits today or tomorrow: he has promised to send pics of the finished product asap. Assuming we're all happy, we can then pay the balance, and they should be on their way to us late this week/early next week...
  • 3 months later...
what ever happened to this?
After 13-14 month wait they turned up last week.
I have tried a quick fit and they fit like shit. Not too happy with them
Will be a couple of weeks before I get time to refit and rework them.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
