sorry if this is abit of a noob questioni guys
ive been reading up abit on power modifications, bolt on mods mainly not keen on cracking open the engine. ( r32 gtst rb20)
just wondering, everyone is saying get a different turbo, i think mine has a vg30, but alot of people are saying get a hks 2530, and all different things.
there is this but im just wondering.
what is the difference between running a rb20 stock turbo, a vg30 turbo or a hks 2530 turbo all running the same boost pressure, 12psi for example. apart from the obvious spool time
will the hks produce more power/torque with the same boost? if yes why?
also if you had a grand to spend on an rb20 to make a fair bit more power without running too much boost and keeping standard engine managment what mods would you do? it already has a front mount, pod, free flowing exhuast, bosch fuel pump.
cheers
Alex,
Airflow - simple as that.
A turbo just flows air. Bigger turbo's, flow more air. More air = more power.
So thats the basic part.
However there is a consideration and that is the efficiency of the turbo. Larger turbos generally require you to run more pressure to get into the efficient area of the turbo so that you see the benefit of using them.
EG a HKS2530 you wouldn't put on and run 12psi. It'll probably make 170rwkw. They shine closer to 16-20psi and will make around 230rwkw.
So running the same boost one turbo from another, sometimes, won't give you much power if at all. You need to run the turbo where it is efficient to make the most of it.
VG30 turbo's seem to not be useful past about 16psi, and RB20 turbos about 10-14psi.
www.hotstuffworks.com or use google. Plenty of websites around that will go into much further details.
cheers, makes sense i guess.
i was thinking of upping boost to 14psi, atm it runs about 10-11 according to the cheap boost guage.
if i did this would it be safe, or should i up fuel pressure aswell?
fair enough, so no gains can be had from under the bonnet tuneing, eg boost, fuel pressure, ignition timeing?
would a power fc be a worthy investment? how easy are these to play around with for a DIYer
pressure does not equal volume
thats why one turbo makes more power
think of a car tyre at 40psi
then think of a bike tyre at 40psi
then think of a truck tyre at 40psi
now its obvious to us that the truck tyre has more air volume inside it, ie more air, but the same pressure
so its possible for a compressor wheel whilst it has the same pressure in the pipe work / engine, that it flows more air
the more air the engine has, the more power it makes
read the PFC FAQ in my signature for info the on the PFC and how to use it
the PFC is amazing to tune on any car, even a stock mild GTST , the results are amazing once fully tuned
my car still has basic mods intercooler, exhaust, clutch, tyres, fuel pump, boost controll and aggressive PFC tune, it drives amazingly
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
