selling my rb26 race head, i changed direction with my engine, after experienceing electrical problems with the gtr putting it in a workshop for a very long time and after alot of thinking deciding to change a few things, so hence the sale. i had a new head built for my new setup.
seen about 1500-2000km driving and dyno runs
was part of a setup that made 565awkw @ 21psi on pump fuel, so the head is good for it and is really really strong.
looking for around $7500, which is merely half of what it cost to build! needs to be sold asap to fund new setup.
Parts list:
Ferrea 1mm oversize stainless valves
Aftermarket valve guides
Apexi V-Max SPL springs, retainers and buckets
Apexi V-Max SPL 280 deg 11.5mm lift cams
Tomei camshaft stud kit
Trust cam gears
New stem seals
whats been done to the head:
Ported intake + exhaust runners
Profile guides
Polished + cc'd chambers
Unshroud valves in chamber
Flow benched and runner flow equalised
Steam hole modifications/water gallery modifications
Clearanced for high lift cams
Drilled for 1/2inch head studs
Flow figures:
Lift Int Exh
0.05 51.9 46.4
0.1 100.4 94.5
0.15 147.2 134.8
0.2 186 167.5
0.25 221.3 197.2
0.3 252.4 219.5
0.35 277.5 229.7
0.4 292.9 236.8
0.45 304.7 240.8
0.5 309.2 241.8
heres a few pics before the head was fitted up..
https://www.sau.com.au/forums/topic/306140-rb26-race-head/
hey its only a 3L haha i built a new head because we did specific porting with it after some guidance from o/s regarding circuit work coz thats where i wanna focus most of the car, but its all goin together this week with a T51R KAI, so prob around 500AWKW but really responsive, torquey and a very nice curve. hows ur car goin, my bro saw i i think and tried to tell me to put an auto in it haha
https://www.sau.com.au/forums/topic/306140-rb26-race-head/#findComment-5110161
Are you using that spare os rb30 you have or a nitto crank and rods from croydon?
ye im using the OS RB30 i had here. this car is doing my head in! haha 3 years now
hey sorry i know its a little off topic..
you dont have any rb30 cranks lying about?? i need one to keep my build going.
no sorry. i do have a mad head for sale haha
https://www.sau.com.au/forums/topic/306140-rb26-race-head/#findComment-5111143
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
