Nissan skyline 1996 model series II GTS-T - FORSALE.
transmission: 5speed manual
colour :tungsten silver/gold pearl
km : 95,500km
i have just paid the reg so there is 12months reg left + i will supply the RWC. reg : DISZ-IT (THIS IS IT!)
Comes with all series II options such as dual air bags, ABS, climate control, sports interior etc...
There is not 1 single tear, crack, scratch or nething in this interior. it is in absolute mint condition!
I have had a sound system professionally installed which includes a 10inch subwoofer powered by a 800watt bridged amp, 6inch speakers powered by a 400watt 2channel amp. this is all controled via a JVC LH3105 head deck which is one of the best out at the moment.
the only other interior mods are 2 pillar gauges which represtent BOOST and AIR/FUEL
both are AUTOMETER ultralite carbonfiber series.
the exterior of this car has been kept in immaculate condition, totally unmarked and always maintained to look the best it can. I get the front bar resprayed every 2-3months to get rid of any stone chip, marks etc... before the car is sold i will respray the bar for nothing.
the car has just received a major service, this includes...
New brakes (Bendix exterme racing pads all around)
New tyres (kumho silica 205/55)
New oil + oil filter (engine and transmission)
New Air filter (K&N pod filter)
New sparkplugs (NGK Iridium)
Mobile 1 Fully synthetic is only used aswell as mobile synergy premium unleaded. this car has never had any other fuel in it since ive owned it.
all this was done less than 1000km ago
There are no mods on this engine beside a type 2 turbosmart BOV and a K&N pod filter.
the car is also fitted with Nismo strut braces
this car was never driven had and has never been boosted before. Its ideal for someone looking for a beautiful stock standard car to simply cruise in or its ideal for a performance enthusiast looking for a clean sheet, somewhere to start from scratch to do all the mods you want!
ASKING : 25,500 ONO
If you are intrested call me on my mobile or at home
mob : 0422 23 11 55
home : 9367 8932
ask for matty
This car is located in melbourne and im am really only looking to sell the car locally... thanks
https://www.sau.com.au/forums/topic/30631-series-2-skyline/
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
