Found some wheels i want, so these have to go. Im selling for way less than their worth. GRAB A BARGAIN!
Nismo LM GT2 produced by RAYS Engineering Japan, A rare find nowadays.
F : 17 x 8 +35
R : 17 x 9 +38
5x114.3 pcd
Rims have a tiny bit of gutter rash, and the paint is slightly starting to peel in a couple of spots.
$650 ono
https://www.sau.com.au/forums/topic/306369-nismo-lm-gt2-adelaide/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
