Hi All,
There is this company in NZ that do a good translation of Japanese user manuals and workshop manuals.
If you visit this page and enter your interest then they may decide to actually do it when there is enough requests.
http://www.jpnz.co.nz/afawcs0131171/CATID=...uctdetails.html
  • Like 1
https://www.sau.com.au/forums/topic/306603-v35-skyline-english-workshop-manual/
keep it coming guys, the more the quicker they'll consider it...
even though you may get G35 workshop manual but a translated V35 manual might be better in cases where it's specific to RHD service.
note that this is not a simple user manual explaining how to jack up car, fasten seat belt, etc,
this workshop manual will be the full blown diagram of engine / mechanical parts etc
ask those who has had a workshop manual on an older skyline generations, e.g. R32/R33/R34
it can be quite useful to those DIY work or even for your own reference.
  • Like 1
it helps however Infiniti are LHD. in most cases they are similar, with exception that the electronic wiring diagram have different colour codes, and they do not have TV Tuner.
There are also some cases where a RHD service manual can be a lot more useful particularly when working around engine bays...
  • Like 1
  • 4 weeks later...
  • 2 months later...
I have the R33 engine manual 460 pages just for the engine.
As for fake sign ups, when there is enough interest they will ask for a certain amount of deposits before the start translating the manual.
  • Like 1
  • 2 months later...
C'mon all V35 owners!!!
I am shocked that only 34 people have displayed interest in this manual, for all the little questions people have would it not be easier to look it up in a proper workshop manual than to throw the question out there and receive guestimations as your response?
The chit chat about what people are doing to their rides is great but when posed with particular problems, the best answer will come out of the manual!
  • Like 2
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
