Hi guys,
I have for sale a ASUKA TV tuner Hawk Ranger II that I bought from Chook that was installed in my M35. I have recently upgraded my system and it is not required. Needs to go $175
https://www.sau.com.au/forums/topic/306835-asuka-hawk-ranger-ii-dvb-t/
  • 1 month later...
Hi guys,
What did you upgrade too, another Asuka Brand ?
im looking to buy a DTV for a m35
  • 3 months later...
Hi guys,
Hey mate, if you still have tuner for sale let me know, I'm keen.
Hi guys,
Can i ask you what did you upgrade to
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
