I have a question. Lets say you have a turbo with an ecu that runs a MAP sensor opposed to the stock AFM and a boost leak. What I propose will happen is the air will leak out of the pipes causing the boost to never reach the set level (say 10psi) because of this the turbo keeps spinning harder and harder trying to reach the 10psi however due to the leak it cannot. As the ECU is reading the correct pressure (and temp) in the pipes it injects the correct amount of fuel allowing the car to drive properly. Now would the turbo just keep spinning harder and harder or at least as hard as it has to to reach the boost pressure with the leak, this would cause far more wear and may even destroy it instantly if the leak is bad enough? If so how would you protect against this?
I know with an AFM car the AFM will read more air than is really going into the engine, so the engine massively overfuels causing it to barely run, you then go 'oh shit I have a boost leak' and fix it immediately.
Anyway I am curious as to if my thinking is correct and what you people think about this. As if correct, this could be the source for a lot of turbo failures or accelerated wear on MAP tuned cars.
I guess ultimately it comes down to how much harder the turbo has to spin to overcome the boost leak, if it is 10% it probably doesn't matter, if it is 100% then it would. However if the boost leak has to be so large to make it spin 100% harder, then there probably wouldn't be enough exhaust gas to spin it this hard. I imagine the problem would be more pronounced with smaller (stock) turbos.
Edited by Rolls
https://www.sau.com.au/forums/topic/306859-map-boost-leak-dead-turbo/
with a leak i dont think pressure would exceed a high enough level to damage it
with a reasonable leak i dont think boost would go much past a couple of psi, if that
so the turbocharger would be spinning fast enough to damage it
however
if you clamp the voltage of the map sensor, or it fails and gives a bogus reading
then depending on your boost control, you may have unlimited boost
as the actuator spring never see's pressure, as map tells the solenoid not to open, so it never does
this in turn runs unlimited boost and can kill shit
Do you mean turbo speed/air flow? Because once the pressure reaches say the set limit (eg 10psi) it will open the gate and stop increasing. If you did mean turbo speed then yeah that is my question I guess, how much faster it will spin. Do you agree that it would spin faster though? Because any increase in speed would make this a problem big enough to look into, as any increase in speed will wear your turbo faster.
I agree that with a large leak even with the wastegate closed all the way to redline that it won't be able to make more a few psi, and that because of that there wouldn't be enough exhaust gas to spin the turbo fast. However if we had say a medium sized leak which is large enough that the boost will never reach 10psi (lets say 8psi for example is the max it can reach) would 8psi (with the wastegate closed) be enough to create enough exhaust gas to overspin the turbo? Assuming that if it spins faster trying to reach the 10psi and all the extra air is going out the leak it will just keep spinning faster and faster until it reaches the limit that 8psi can spin it to.
Gah this is doing my head in trying to understand it and explain it. I think the only real way to test would be to use a turbo tacho and a variable sized hole on the intake.
Edited by Rolls
no, i dont think the physics would support an ever increasing acceleration of the compressor wheel
remember with a boost leak the engine is working no where near as hard, which means less exhaust gas
less exhaust drive, means lower compressor driver as well, so i think the turbocharger wouldn't be ever increasing its turbine shaft speed
if its leaking enough to cause any damage to the turbo and you cant notice it then you shouldnt be driving a turbo car, simple.
It is just a theoretical question, I would hope that the average Joe would hear it and notice as well but that is not the point of this thread.
i still dont think the physics would support it
if there is a leak on the intake side the actuator never opens so all the exhaust gas must run via the turbocharger wheel (instead of bypass)
so technically the turbine speed is ever increasing, but and it's a big but, the engine load is basically jack all, as there is no decent positive boost pressure forcing more load on the engine
I agree with what you proposed if there is a very large leak. However if you decrease the size of the leak so that a decent amount of the air is going into the engine (remember a stock turbo can hold full boost at 3000rpm with half throttle, let alone redline on full) so let us say half the air is going in and half is leaking out. Now being as a stock turbo can run full boost at 3k with half throttle surely there would be enough exhaust gas to allow the turbo to keep increasing in speed to some point?
edit:
I've made the same thread over on performance forums to get a wide range of opinions and GTSboy has explained why he thinks it would overspeed with the aid of a compressor map. I guess the only thing to argue now is whether or not you have enough exhaust gas to keep the turbo spinning faster, personally I think with a small undersized (stock) turbo you would have no trouble doing this.
http://www.performanceforums.com/forums/sh...php?p=840645505
Edited by Rolls
i think that it's either a non issue in the real world and its not common or the physics dont support it an ever increasing turbocharger shaft speed with a leak
theres no way either of us can prove it either way without a turbocharger shaft speed guage and some testing
garrett sell and recommend a turbocharger shaft speed guage to monitor the turbocharger shaft speed
maybe look into one of those if you are that keen and that precautious on it
i think there are more common elements that cause turbocharger failure in today's day and age
i would assume and logic would say so that the turbocharger is pretty well balanced and setup to maitain a higher than efficient shaft speed
for how long is debatable, but it would be at least able to cope with this for a short period
i think elements such as poor oil flow, oil contamination, excessive pressure surge from no BOV and compressor damage (from open mouth or poor pod filter) are your likely causes of turbocharger failure
Without a doubt there are, this is more just for some interesting debate, I'm running an AFM in my skyline now so it is not even a possible issue, I am just curious of the physics and whether it can occur.
I agree that we need a variable sized hole and a turbo tacho to ever prove this one way or the other, still I think it is interesting to discuss.
understand
so are we trying to decide if the scenario is any different with AFM vs MAP?
or if its possible in either way to fry the turbo as a result of a leak?
With an AFM I imagine the car would just run super rich and you'd notice straight away, unless of course the car was tuned from scratch with the boost leak. I wanted to get a better idea of whether the situation was possible with a MAP, I'm still not 100% convinced but I think it is quite likely, to what extent though? I do not know. Only way to tell is as you said, with a turbo tacho and a controlled environment.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
