  • Replies 131
Hey just wondering if you got the middle part for the rb25det , so the 2 bolts that screw on and the hose? cheers man
Sorry can't help with these.
  • 3 weeks later...
  • 1 month later...
hi,
I have a dash 10 or a dash 12 for the rb26. As for size it would depend on the catch can fittings or your personal preference i think. The dash 12 is bigger by about 2mm in diameter and will flow a little more.
I think the dash 10 is enough and have not had any complaints with this size. I have had a request for a dash 8 for a rb26.
So short answer i would say its personal preference and also what you are connecting to.
Thanks
