Yeh thanks guys for coming along and showing support on the meet, just like a little community here on the forums, i know the weather tonight is a little set back for some so hopefully next time will be alot better for the turn out.
Thanks to vtrvtr for giving your support coming all the way from Kiama. (also had the cleanest car)
  • Replies 171
Let's see some pics!
Sorry couldn't make it guys, had a crap/long day at work and have been driving the v for work the past 2 days as my old man had to borrow my daily, kinda made me not want to drive it. Was supposed to hit up natio with my crew as well tonight but the weather laid rest to that.
Interesting, a few Vs around the stgeorge area...even one in penshurst. But i hardly ever see them lol.
Will definitely come to the V cruise when it's organised.
Hey all, great meeting you all on friday.
Got plenty of pics, i've had a quick look through and their are a fair few nice ones.
I havent had a chance to really sort them out yet, but i might throw some easy ones up later today.
+++ Triple thanks for Messiah taking the pics, awesome job man, made the night im sure.
I know he spied some shots of my carbon fibre engine bay so im keen to see that, just wish id polished it =[
I've got a new CarPC edition for you all in a week or 2 which im sure you'll all like.
as promised... here is a tiny tiny hint of whats to come.
below is a link to the flickr set I'll be adding the pics to as i sort them out. It only has one in there at the moment, and that shouldn't be considered a finished shot for a few reasons... one listed below.
http://www.flickr.com/photos/justplainnift...57623451095769/
I've noticed that the water drops on the black cars plays merry hell with the hdr process, so this will require some touching up. note to self for future... bring a shammie.
Looks SICK! =)
Looks amazing...ill put up some of mine tonight when im back from work. Cant wait to see the pics messiah
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
