Ok a brief history... just did a timing belt plus a few other things on my RB20. Threw it back together and it was running fine... then it just stopped running. The engine is still getting fuel so i'm assuming i have an ignition problem.
The engine has larger cams... probably doesn't make a difference but just throwing it out there.
Also when i put it back together i didn't put the upper timing cover back on because it had a clear one on there which was too much of a problem because the bubble on the intake cam size for the vct on RB25's was causing the intercooler pipe to foul on the fan. I've since read that I should have spaced out the cam angle sensor when running it without a top cover but couldnt' find a reason. Could doing this have damaged my CAS? The keyway on the end of the cam still seems to be intact. Looks like there's a bit of gunk inside the shaft of the CAS but it still has its half moon shape. It is very tight when sliding it onto the cam though, also once it's on it's hard to move it left and right.
Because I live in the sticks there's no one with another skyline that i can borrow a CAS off to test it.
I've checked all the plugs and connections i can think of that might relate to the problem. The car has a brand new set of splitfire coil packs. I've put new plugs in it.
Just before it stopped running i adjusted the timing slightly by moving the CAS. I also adjusted the idle with the screw on the AAC valve.
Thoughts or ideas? I'm pretty stumped at the moment!!
Thanks guys!
https://www.sau.com.au/forums/topic/307570-ignition-problems-rb20/
take the cas off, take a coil out leaving it plugged in, whack an old spark plug into the coil and rest it against the intake manifold. turn the key to on but dont crank it, now come back to the cas and spin it in any direction.. that plug should start sparking. if not, try another cas.
the cas should spin very freely, if its stiff, its rooted. do this and report back.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
