  • Replies 302
Posted Images
at this stage Krishy, I'm picking the Lions for a top 3 pozzy and Freo top 6 or 7...............but unlike the lions, Freo are likely to break your heart by the 1/2 way mark of the season
EDIT: Tangles got in before me
Normally I would agree with the Freo comment as they really are an off/on team with the way they play. But after watching there first few matches and beating Geelong and only loosing to St Kilda by a couple goals I think they will play good football for the entire year (they just seem to have a great deal of enthusiasm this year). I predict them to finish just out of the top 4 as that will be filled with stk, cats, lions, cwood. I still think that the crows will finish above the power on the ladder but both teams will struggle to make a finals appearance.
Ryan
https://www.sau.com.au/forums/topic/307800-afl-2010/page/4/#findComment-5192375
unfortunately the opposition wasn't as good in the Nab Luke but otherwise agree.
Ryan, if your boys can put in a good showing against the Bullies & Lions, then they are the goods cause they're the last 2 teams to benchmark yourself against.
Pies are also top 5 no doubt but they're also heartbreakers cause one week a bottom side will roll them and the next week they'll smash a top side....go figure :(
https://www.sau.com.au/forums/topic/307800-afl-2010/page/4/#findComment-5192408
Ryan
I agree Ryan, they have finally got their shit together and it shows. I just hope they dont come up against a top team that thrashes them, it will drain their confidence.
https://www.sau.com.au/forums/topic/307800-afl-2010/page/4/#findComment-5193028
I just want the western bulldogs to win a premiership.
just once
please god?
please?
-D
https://www.sau.com.au/forums/topic/307800-afl-2010/page/4/#findComment-5193088
i caught the last quarter, dogs were running rings around the crows. Very bad form.
Hope port puts up a decent fight tomorrow night. Not too fussed as a loss is pretty predictable, but that last half against geelong last week was a bloody embarrasment... Want to see a solid effor for the full 4 quarters
https://www.sau.com.au/forums/topic/307800-afl-2010/page/4/#findComment-5197138
i dont know why but i ended up watching the whole game......crows started off really well but turnovers and bad decisions cost them the game.....simple skill errors as well....bt the 4th quarter the dogs had a 40 something lead......not a good start for the final quarter.....i think they will be hard up against the power
https://www.sau.com.au/forums/topic/307800-afl-2010/page/4/#findComment-5197644
the handball is killing the Crows in the 3rd and is the Truck too slow or is he scared of Big Bad cause he's finding alot of space?
I would've dropped him after the last 4 games, but in the first half on Friday night I think he played his best football so far this year.
https://www.sau.com.au/forums/topic/307800-afl-2010/page/4/#findComment-5200233
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
