Hi all, long time since I posted
Trying to sell my plates I've had for a number of years now. Since the car was sold interstate, I have no use for them
I have advertised them on eBay and currently have them up now - http://cgi.ebay.com.au/R32-Skyline-GTSt-Pe...=item27af52e730
What do you guys reckon they are worth? Is $350 too much or should I be asking more?
How hard is it to transfer them over? Any of your experiences would be good to hear
Cheers,
Chris
https://www.sau.com.au/forums/topic/307903-what-are-my-plates-worth/
what you're really selling is your intellectual property, because you thought of it.
spot on.....if you think that your one random though is worth $350 then by all means its worth 350 lol......nice plates though
exactly its the wierdest market around. i cant beleive how much people have paid for plates in the past but each to their own.
something like "godzila" would be worth something but i dont think your plate will be that sought after.
good luck all the same
Is it actually legal to sell plates? Dont they remain the property of transport sa at all times?
The right to display the plates is held by the owner, and can be transferred for money.
It's a bit like if you had XXX-XXX plates on your car and someone nicked them, it doesn't mean you lose the right to display them. You just get a new set (if that makes sense!).
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
